Forum: Old versions
Topic: Help me newbie^^
I just brought virtual dj pro full last week and i wan to change my mv song into karaoke mode.I succesed made it with removing a vocal but i dunno how to save it T.T....Anyone help pls
geposted Mon 20 Jun 11 @ 12:43 am
if you play the de-vocalized track and use the record option you can save your track. go to the record tab and click on record audio, click on the config button and choose your format. i use mp3 which is widely accepted and playable on nearly any device plus i can choose any audio resolution i desire. i often go 320 Kbps but if you run into buffering errors, skips or whatever you can lower the res down as low as you need. even 128 isn't terrible to most people (i hate it but what can you do). that should help ya out.
geposted Wed 22 Jun 11 @ 3:12 pm
please register ur software here as well when u get a chance
geposted Wed 22 Jun 11 @ 5:47 pm
For best results, you should purchase proper MP3+G karaoke songs from vendors such as Sound Choice, Sunfly, etc.
These will be a proper instrumental version of the song as well having on-screen lyrics to sing along to.
Attempting to remove the lyrics from a song is not an easy task for a computer to do and the results will vary. For some songs it may work well. For others it may work very poorly.
geposted Thu 23 Jun 11 @ 5:48 am
