Forum: Old versions
Topic: Numark Mixtrack Pro out to two speakers.
Hello again guys,
Today i tried hooking up my Mixtrack pro up to two speakers instead of just one. I tried to plug in the RCA cables into output 1 and connect to speaker 1, and output 2 RCA cables to speaker 2. However, sound only came out of speaker 1 (the soundcard is set to channels 1&2) the cue was coming out of the other speakers and my headphones. is there anyway to separate the sound so i have the main sound going out outputs 1 and 2 to each speaker while also keeping my headphone cue intact?
geposted Thu 23 Jun 11 @ 7:33 pm
The outputs 1 (left-right) are the master sound output for Mixtrack. So only there you should connect speakers. Outputs 2 (left-right) are the secondary output which is used for headphones input jack.
The second stereo output No2, exists in order to use those 2 stereo outputs to route 2 decks of Virtualdj in to a external mixer, but this is a feature that is available in Pro Full version.
geposted Thu 23 Jun 11 @ 10:51 pm
So what would be the easiest/most advised way to play the master output through two self amplified speakers each with their own RCA inputs?
geposted Fri 24 Jun 11 @ 12:18 am
pls how do i use my virtual dj pro with two speakers ...using a mixtrack pro plss...
geposted Fri 06 Apr 12 @ 11:43 am
geposted Fri 06 Apr 12 @ 3:26 pm
