Hello,
I'm new to Virtual DJ having just downloaded the free version. My question is, can I record a hour long set without having to do it all in one go? Is it possible to record a few tracks now and then cue others up and then press continue and carry on where I left off. At the moment it just keeps on overwriting what I have done so far? I would like to creat a hour worth in one separate file.
Thanks for any help.
Pad
Pad
geposted Sun 24 Jul 11 @ 12:08 pm
so rename the new part in the config. record your first part as part 1 and the second as part 2 etc. either that or move/rename your first part to correspond with which part is which.
geposted Sun 24 Jul 11 @ 2:59 pm
I use the record feature sometimes during a special speech or singing.
I rename each track when done.
I think it would be better if VDJ records on a default filename, then when you press STOP recording, a window pops up and ask you to NAME/RENAME the file (something along this lines).
geposted Mon 25 Jul 11 @ 4:06 pm
It already does do that, a window pops up and ask if you overwrite the file.............if you don't you'd then open record config and type in a new name...........
Huey
geposted Mon 25 Jul 11 @ 7:42 pm
yea I know you name the file before recording.
If you accidently press record, you will prompted if you want to overwrite (Y/N). If you press "NO" then you need to click on config and name the file.
I was going for an instant ASK the filename if the answer is "NO" (saves some step).
OR just press record at anytime and then ask the FILENAME after you press STOP recording.
Other than that, it's really no biggie. I just thought iit could same some steps.
geposted Tue 26 Jul 11 @ 12:02 am
Yeah I see your point and I agree. With some other software you name it after you've recorded it which is nice!! Maybe post this in the wishes forum, can't hurt and never know it could become a reality.
Huey
Huey
geposted Tue 26 Jul 11 @ 12:09 am
ive had some issues surrounding this in the past. at one point, the software seemed to record each session under a different name, eg. latest set 0001, 0002, 0003 etc.. for some reason this wasnt a permanent thing.
i do feel however that is should be. maybe it could be impemented into the next version.
geposted Wed 27 Jul 11 @ 6:31 am
