Forum: Old versions
Topic: can't get songs from my iPod?
I just downloaded virtual dj free version and I can't figure out how to play the songs from my iPod. I just got this computer and also my songs are not from iTunes. if anyone knows how to fix this problem, please let me know.
geposted Tue 26 Jul 11 @ 10:57 am
VirtualDJ can play your songs only from your Hard/Cd/DVD Drives. Can not load or use any songs located on Ipod/Iphone/iPad. You need to sync your ipod with your computer and transfer your music files to your computer.
I'm not to sure with Virtual DJ Home. I use Pro and I have one of the first iPod Nano's that came out and this is what I do:
Open VDJ and on the bottom left column where you choose your file - choose Volumes - Ipod - Ipod-Control - Music
Then it will be listed as F00,F01,F02, and so on. Click on some and transfer the songs into a playlist.
A little messy as they are all sorted out but hey, it works for me.
When the iPod is plugged in, click on the little iPod icon in the lower right corner of the iTunes window (or select Preferences > iPod > Music).
This will open a window with a series of check-boxes. Select "Manually manage songs and playlists."
From now on (unless you change this setting) iTunes will will NOT automatically load or erase any tracks when you plug in your iPod. You'll have to do this stuff by dragging and dropping tracks or playlists. So all your music on the iPod should be safe when you reformat your computer.
Read more at Transferring iPod Songs to PC
http://www.iphone-mac.com/how-to-transfer-and-copy-music-songs-from-ipod-to-pc.html
Hi, i just downloaded virtual dj on my computer. And then i made a remix of david guettas lovers on the sun. so i want to save it and send to my phone so ican listen to it, but i dont know how i do that.
how can i send songs ive made on the vdj to my iphone?
You'll have to do this stuff by dragging and dropping tracks or playlists. So all your music on the iPod should be safe when you reformat your computer.????
lol
Please refrain from bumping very old topics.
Thank you.
