Hello;
Need some help!!!! I am using VDJ 5.0 rev 6. I am not using Virtual DJ in a conventional manor.... I play in a rock band and we use virtual dj to play samples and mixes that are in our songs.... it works great, BUT, I am trying to trigger the samples via midi foot controller.... Need to free up my hands to play guitar...
I am using a ROLLS MP128P Midibuddy, which is a standard midi controller... I have a HOSA Tracklink Midi to USB interface.
The interface seems to have installed properly...
In VDJ config, remote control tab, I click on general Midi, Activate, and it turns green, click on config, Add, select samples from the list on the left, then sample_Play from the list on the right.... it says "Autolearn" at the top of this window... I put in the #1 for the first sample, I then press button #1 on the MPX128P and nothing happens.....
can someone give some insight on what I need to do here... PLEASE. Does this just not work, or is there a foot controler out there that we know works?
Thank you in advance for the help!!!!!!
email is ********@************
[Sorry, E-mail addresses and other contact details are not permitted for unlicensed users.]
geposted Tue 26 Jul 11 @ 9:55 pm
you can use action learn to get the midi button then type in the sample followed by the number, then the action eg. play_stop
sampler 1 play_stop
sampler 1 play_stop
geposted Tue 26 Jul 11 @ 10:47 pm
v5.0.6 is a very old and out of date version of the software. There have been many changes and improvements to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.4
Please register your serial number on the page http://www.virtualdj.com/users/edit.html and then upgrade to the latest version: http://www.virtualdj.com/download/updates.html
Or purchase the latest version from the following page: http://www.virtualdj.com/products/comparison.html
NOTE: The above instructions will only work in the latest versions of the software.
CONFIG -> Mappers -> Simple MIDI Wrapper can be used for basic MIDI mapping in VirtualDJ v7 - See http://www.virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
However, some MIDI devices may need a proper definition and mapper file written to work correctly and optimally (E.g: Working button LED's.)
geposted Wed 27 Jul 11 @ 6:02 am
Hello, thank you for the reply and info.... I will update the software and try that, however, is it pretty much a given that this controller will work, or is it a hit or miss thing? Also, does the MPX129P controller need to be on a specific midi channel? I currently have it set to channel 16 (OMNI) or does that matter.... also, you mentioned that a definition or mapping file may have to be written? is that something I would do, or can you find them on the web? And, if written, where is that file placed or inserted into VDJ? Sorry for the lack of VDJ knowledge... im a guitar player by trade... all of this is greek to me. Thank you for the help!!!!
geposted Wed 27 Jul 11 @ 8:52 pm
