Forum: Old versions
Topic: PLEASE HELP! need info
Hey there, tonight me and my friend are doing our first gig, i am using a hercules rmx and my buddy is using a numark, both on our macbooks.
What cables do we need to switch off without killing the music? I was thinking an RCA Y Splitter, but i wasn't too sure and wanted to get advice on here. Sorry if this was a repeated topic question
Please help! Thanks!
geposted Sat 30 Jul 11 @ 12:42 pm
Haui70PRO InfinitySenior staffMember since 2008
Never tried to run two LE versions at the same time, but maybe it is possible.
What numark controller do you use additional to the RMX?
Also with a LE version?
geposted Tue 02 Aug 11 @ 5:38 am
If you are going to be both playing off separate computers, then ideally you should use a standard hardware DJ mixer to allow to connect both computers simultaneously. If you are doing a gig at a bar of club, then they should already have a mixer installed as part of their sound system.
This will allow you to seamlessly switch, i.e: The master output of your RMX goes into channel 1 of the mixer and your friend's Numark master out goes into channel 2.
geposted Tue 02 Aug 11 @ 6:43 am
