Forum: Old versions
Topic: 7.04 - Loop - Audio Drop Out
Since upgrading to VDJ 7.04 I've noticed what I think is a bug.
I'm using my Allen & Heath Xone:4D as MIDI controller and also the internal soundcard.
This hasn't been an issue with previous versions.
If I engage a loop, after it's repeated a few times I start to get audio drop out, then it comes back, then it goes and so on.
If I disengage the loop there are no further drop outs.
Loop on again same problem.
If I go back to 7.03 or 7.04 the problem does not present itself.
That's the really buggy part.
I'm also noticing some slight drift when using CD Timecode that again does not exist in the previous versions.
Hopefully someone can help.
Ross
geposted Thu 04 Aug 11 @ 5:26 pm
Interesting... I use the Numark Mixdeck and it does not do that. Issue could be the sound card, Midi is midi unless it controls your gains. If vdj controls the gains and it does it then it could be a bug indeed.
geposted Fri 05 Aug 11 @ 10:34 pm
It's not the soundcard. Or if it is, then it's a very strange fault that only happens with 7.04.
It doesn't happen with 7.03 or 7.02 or Traktor Pro 2.
VDJ is set to Automatic + Remember for Gain.
Why do you think this might be the issue.
Incidentally does anyone know of a way to set the automatic gain lower?
Ross
geposted Sat 06 Aug 11 @ 9:56 am
I have the same issue using a Denon DN-MC6000 and version 7.0.5. Have also had the same problem when using Denon DN-S3700s.
geposted Sun 08 Jul 12 @ 1:12 pm
Haui70PRO InfinitySenior staffMember since 2008
This is a nearly 1year old topic ;-)
I only would advice you to use at VDJ Config - Performance the Advanced Streching.
Maybe this will help, while using the MC6000.
http://www.virtualdj.com/wiki/Forum%20Rules.html
Quote :
Do not bump an old topic that is more than 1 year old. Old topics may no-longer be relevant to the current version of the software. Please open your own new topic in the appropriate forum.
closed
geposted Wed 11 Jul 12 @ 6:00 am
