Forum: Old versions
Topic: Help Recording With My VMS4!!
I Recently Bought The VMS4 && I Can't Figure Out How To Record My Mix With It.!
I Went To CONFIG @The Top Of Virtual DJ Pro 7 & Went To Outputs And Put Advanced Config.
Then Put : Deck 1 - ADJ ASIO (ASIO) - Output 1&2
Deck 2 - ADJ ASIO (ASIO) - Output 3&4
Record Loopback - ADJ ASIO (ASIO) - Output 1&2
Then I Tried Recording My Mix && Still Doesn't Work.! Please Help.!!
geposted Sun 21 Aug 11 @ 11:54 pm
geposted Tue 23 Aug 11 @ 7:49 am
what if your computer does not have a line in? can you use a 2nd sound card? I have a behringer UCA222....can I use this as my line in? although I have the VMS4 connected also?
geposted Wed 24 Aug 11 @ 1:08 pm
