Forum: Old versions
Topic: Track Won't Play?
I load a track onto the deck and press play and it won't even start? Any ideas? Also I am using the free home edition.
Also it says, error on deck 1
geposted Mon 22 Aug 11 @ 11:29 pm
If you get 'Error' when trying to load a song, then it means that the song in your database is no-longer valid. This is usually caused by either moving, renaming or deleting the song outside of VirtualDJ, so the entry in its database no-longer points to a valid file.
To fix this problem, use VirtualDJ to browse to the drive(s)/folder(s) where your music is located, right-click on them and choose Add to search DB.
Once you have done this, go to CONFIG -> Browser, choose each drive in turn where you have music stored and click on CHECK.
If any problems are found, click on FIX.
You can remove the old redundant database entries by clicking on CLEAN.
If it is a song that you have never loaded before, then check that is not corrupted or an older DRM protected Apple iTunes file (.m4p) - These cannot be played in VirtualDJ or any other non-Apple application or device.
geposted Tue 23 Aug 11 @ 4:41 am
