Hi, just bought a Kam Digi One & when I open VDJ LE get that error message, please help!
geposted Thu 25 Aug 11 @ 5:38 am
Please update your directx drivers, then re assign your sound card and channel assignments in config/sound card settings.
http://www.microsoft.com/downloads/en/confirmation.aspx?familyId=04ac064b-00d1-474e-b7b1-442d8712d553&displayLang=en
Create a folder on your desktop and save it there.
Then find the set up exe and run it.
geposted Thu 25 Aug 11 @ 8:11 am
I get the same messge with my kam digi mini with my new windows 7 64bit laptop, tried updating direct x, any ideas please.
regards robbo
regards robbo
geposted Sun 18 Dec 11 @ 10:40 am
Hola me compre una computadora toshiba y como dj utilizo el controlador ddj wego pero al momento de cargar una canción en el deck opuesto hay una interferencia de la canción que esta la aire o sino empieza a reproducir lentamente.
Alguien que me pueda ayudar.
Agradezco de antemano.
geposted Sun 10 Nov 13 @ 3:33 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
geposted Mon 11 Nov 13 @ 11:26 am
I have downloaded the directX program and the error message still pops up, how do I apply it to my 19mxr mixer? so that I may be able to use virtual dj program.
geposted Sat 18 Jan 14 @ 4:10 pm
Make sure that the soundcard of the mixer is not set as windows standard sound device.
Then startup VDJ again.
geposted Tue 21 Jan 14 @ 2:45 am
Error in sound driver(Directx/WDM)(Forum PC Version Technical Sipport)
geposted Tue 19 Aug 14 @ 7:23 pm
Hello i bought the xdj-r1 4 months ago and till now i haven't found any virtual dj working with it always problems and problems the virtual 7 le is not working also can you please send me a link to download it and make sure its full so i can play with xdj-r1 ????? seriously we got tired from the virtual dj
geposted Sat 30 Aug 14 @ 2:25 am
You can download the latest LE version from your account. If you require the full Pro version then you will need to purchase a license.
geposted Sat 30 Aug 14 @ 3:56 am
"Error in the Sound Driver of DirectX"
That's the message I get when i try to start VDJ on my PC. I can't play any songs or videos.
Does anyone know what may be the problem? I've tried to reinstall the sound drivers on my computer but nothing gets better.
I am very happy for any kind of help!
geposted Thu 02 Apr 15 @ 1:24 am
Download and install this
https://www.microsoft.com/en-US/download/details.aspx?id=34429
geposted Thu 02 Apr 15 @ 6:35 am
