Forum: Old versions
Topic: Reloop Digital Jockey 3 Master Edition - Page: 2
You need to use <led note="0x1E" channel="0" min="0x00" max="0x10" name="FX_P1_BAR_A_34" deck="1" /> not <bar note...
Thank you for support, I hope to make the complete release next weeks.
The commands availables are really so many and create a correct definition file is really long and boring.
Hej Digitaljockey
I can see you are way ahead of me. Can't wait to try this map this evening. Many thanks from me.
I mean to finished the complete map to 4 decks, but I would like to activate something like soft takeover feature to assign to mixer zone.
Exist something like this in VDJ Script?
It seems is a firmware problem or something doesn't work in communication through software and hardware.
In any case I published the updated map available for 4 decks.
https://virtualdj.com/addons/13690/Reloop_Jockey_3_ME.html
Reloop Jockey 3 ME V. 1.0
This map works also with 4 decks
PLEASE READ IT!
- For unknow reasons the mixers controls and pitch sliders don't have the unlink (soft takeover) feature when you switch from deck A-C and B-D. For perfect 4 decks use we will wait a firmware update and a native mapping.
- Deck A-C-IN1 and Deck B-D-IN2 switches:
Before to lunch VirtualDJ please place these switches to A and B position or after lunched the software move the switches.
- For firmware reasons when you switch to IN1-2 the volume of decks C-D goes to zero, sorry but it's impossible to block this.
- Jogwheels must be set at 512 steps using fimrware controls (read Reloop Jockey 3 ME manual)
- Jogwheel doesn't work without one of four jogwheel buttons pressed
For map details read the attached text file.
