Forum: Old versions
Topic: Noob, Help with Vinyl Timecode set up
Hey everyone, i got my rig and i'm trying to figure out how to connect my turntable to VDJ and use the time coding system.
I have my TT, Serato Scratch live Vinyl,
A behringer UFO202 (2in, 2 out) usb soundcard
I can't seem to get VDJ to recognise the input from my TT
I can play music from the soundcard through my speakers
in the config, i have
Input: single timecode
Output: external mixer
Sound card: behringer usb audio ( my sound card)
but after i click 'apply' i get a notice saying that there are not enough channels
It should be fine in my eyes as i'm only timecoding 1 TT
Any ideas, tips, suggestions are greatly apreciated.
(and yes, i installed all the proper drivers for my card)
geposted Fri 02 Sep 11 @ 4:06 pm
Alright, I put the output to just the regular external,
and i got the timecode set up, except it plays the song i have lined up, and the 'wirrr' pitch from the timecode vinyl.
geposted Fri 02 Sep 11 @ 4:55 pm
What version of VDJ are you using?
geposted Mon 05 Sep 11 @ 4:31 am
djesco1PRO InfinityMember since 2007
Here is a quick video walk through. http://www.youtube.com/watch?v=CSMwQD-3euY
Keep in mind you must be using a VDJ Pro version.
This works for both Mac and PC :)
Hope this helps. BTW you can do video mixing with it too.
BR,
DJ Esco
geposted Mon 24 Oct 11 @ 5:02 pm
Check this vid i done i had the same problem , There is another behringer UCA202 which i believe doesnt have this issue, if you cant exchange it . heres what i did http://youtu.be/iYIiqVGjcVk
geposted Thu 22 Dec 11 @ 4:31 pm
