I have searched for a solution for 3 days. I have a mixtrack which I just bought.I cannot get it to work with the software. Yea I saw other who had conflict with logitech, however this is not the case. I'm running xp on a laptop.It just will not responde to the software at all.
I have even updated the software.Please help
geposted Wed 14 Sep 11 @ 2:10 am
Please see https://virtualdj.com/wiki/midinotdetected.html
Also, try using a different USB cable and/or different USB port of your computer. Make sure that you plug it directly into your computer, not via a USB hub.
If the problem persists, then you may have a faulty MixTrack. Please contact the manufacturer Numark support for advice: http://www.numark.com
geposted Wed 14 Sep 11 @ 10:01 am
