Forum: Old versions
Topic: VDJ 7.0 Sync Problem
Hello guys!
My Set up:
Toshiba Satellite WIN7
VDJ 7. Pro
CDJ400 x2
DJM600 Mixer (External mixing mode) out to my behringer speakers.
DJ MK2 usb to PC (customized for effects and loops only)
The Problem:
i seem to have an issue with VDJ 7.0 Pro,
when i mix with without software, my beat matching and fine tuning sounds perfect (Most times :) )
when i use virtual VDJ, i use the sync button most times, but its never 100% so i used to fine tune the songs and done!
however Now i cant seem to fine tune most songs.. you can still hear the beats clashing... maybe most ppl wont notice it... but DJ's will for sure.
i know of many ppl that has this issue. not all of them notice, but when you hear them play you can tell.
could it be a driver? latency? software bug?
please let me know if there is a way i can fix this.
Thanks!
geposted Wed 14 Sep 11 @ 11:27 pm
The sync is only ever as good as the CBG (beat grid).
If the CBG is off, the sync will be off.
The CBG is only as good as the music.
Depending on what type of music you're playing, sometimes the CBG will always be off - because it works on the principle that beats are steady and stay the same all the way through the song. Not all music is like that.
Give us an example of two songs that you're trying to mix, that don't sync.
geposted Thu 15 Sep 11 @ 11:42 am
