Forum: Old versions
Topic: help with gain problems!!
hey just recently i have started recording my mixes and everything was good until not too long ago. i noticed when i would make a transition to another song the gain would automatically move, sometimes causing it to be extremely distorted and sound terrible.
i am using a numark mixdeck and this problem only just started happening. the only cause i can think of is because i just started using mp3gain to control the volume levels of all my songs so they would match. but now i have run into an even bigger problem!
thanks for the help and if theres anymore info thats needed from me please let me know.
geposted Fri 16 Sep 11 @ 10:38 am
I could be wrong but it sounds like VDJ is re-analysing your tracks again. I'd go through and re-analyze your tracks again and see if that helps.
Just kicking ideas out there
Huey
geposted Fri 16 Sep 11 @ 11:03 am
ok thanks, how can i scan them with virtual dj to stop this from happening? ive selected all the songs and right clicked, but it doesnt give me an option.
also, what should i have my masters set as? on both virtual dj and my mixer.
geposted Fri 16 Sep 11 @ 11:43 am
When you right click on your tracks you'll another window open when you move the mouse over "BPM", it should say "re-analyze". Hit that and let it do it thing.
As far as where your levels should be, that's gonna be different for everyone. I would say since your using a Mixdeck (external mixer), I wouldn't touch anything on screen. Meaning leave everything zeroed out. Only adjust the levels on the Mixdeck. That's what I do with mine.
Hope that helps
Huey
geposted Fri 16 Sep 11 @ 11:50 am
okay yeah it does help. i just didnt realize scanning bpms also analyzed the song volume.
geposted Fri 16 Sep 11 @ 12:07 pm
okay so scanning the bpms didnt work. but i found out how to fix it!
*************opened config, options, AUTO GAIN was enabled so i DISABLED it and now the problem is fixed!
geposted Fri 16 Sep 11 @ 2:45 pm
