HI, IVE JUST BROUGHT A MIXTRACK PRO THAT COMES WITH TRAKTOR I HAVE VDJ7, WILL IT WORK WITH VDJ7 STRAIGHT OUT OF THE BOX OR WILL I HAVE TO DO SOME CONFIG? IF SO HOW DO I GO ABOUT THIS???
MANY THANKS FOR YOUR HELP ;)
geposted Wed 21 Sep 11 @ 7:41 am
Providing that your VirtualDJ is up-to-date then it should work straight out of the box as a MIDI controller.
You will need to configure the sound card though: http://www.virtualdj.com/wiki/MixTrack%20Pro.html
You can download the latest VirtualDJ Pro v7.0.5b from: http://www.virtualdj.com/download/updates.html
geposted Wed 21 Sep 11 @ 2:23 pm
thanks alot for your help
geposted Thu 22 Sep 11 @ 7:20 am
