So I recently got my hands on the Launchpad. I love the interface and using it with Live, but I have a problem. I have been using a Mixtrack Pro for most of my sets and bought the Launchpad in order to use as a sampler/effects controller. I want to be able to use both and wanted to know if there was a way to dual map them onto VDJ? I know I can do it in Traktor, but I want to keep away from that program (its not my favorite), and I as far as know Serato wont support this setup at all. Is this even possible? Or do I have to just open up Live and VDJ and hope my samples are time-synced correctly when dropped :D
Thanks for the feedback.
geposted Thu 22 Sep 11 @ 1:37 am
It's not natively supported by VirtualDJ, but there is a user-made mapping available frrom http://www.virtualdj.com/addons/controllers.html?category=best&order=default&search=launch
Or depending on your computer knowledge/experience, you can map it yourself: http://www.virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
You will need to purchase the full VirtualDJ Professional to be able to use MIDI controllers for longer than 10 minutes and to be able download custom mappers: http://www.virtualdj.com/buy/index.html
NOTE: If you have VirtualDJ LE for MixTrack Pro then this will only work with that controller. You can upgrade from VirtualDJ LE to the full Professional at a considerable discount.
geposted Thu 22 Sep 11 @ 4:36 am
