Forum: Old versions
Topic: Sounds "dragging" ??
Having a problem. When playing, i experience a "drag" or "lag" in my tunes...like the pitch goes up and down slightly, or it sounds like someone put their finger on the record, ya know?
hp g62-407dx
2.6ghz dual core AMD phenom II processor
3gb ram
320gb hard drive
HELP!
geposted Sun 25 Sep 11 @ 9:20 pm
mate have you get pitch/eq reset checked in options.
also do you have keylock highlighted on you skin,
sounds like something/or shortcut is causing this problem
geposted Mon 26 Sep 11 @ 5:28 am
yk23PRO InfinityMember since 2006
Use Advanced Strecthing under Master Tempo in the config. That was the only way I could get rid of it.
-David
geposted Tue 27 Sep 11 @ 9:43 am
