Forum: Old versions
Topic: Crab Scratching with Mixtrack Pro.
tjordonPRO InfinityMember since 2011
Hello fam. Has anyone mastered the crab scratch with the mix track pro. For some reason, it seems as though the mixtrack pro is not sensitive enough to handle it. I have played with the settings, and still nothing. I cannot find any settting for the cross fader to adjust it's sensitivity. Is this just a drawback with the software or hardware?
Any help on the settings would be greatly appreciated. New at this and trying to learn. Much Mahalo!
T-Rock
geposted Sat 01 Oct 11 @ 2:32 pm
the crossfader is really weak on the mixtrack and not replaceable... I would forget about crab scratching until you get a better controller. I have a reloop jokey 2, it's fader is amazing, but the fastest it will scratch is a 2 click flare, look it up
geposted Sat 01 Oct 11 @ 11:20 pm
No doubt. Good looking out. I was actually looking at getting the Reloop 3, however, I have seen some not so good reviews on the scratching latency. Everything else on the device seems awesome.
geposted Mon 03 Oct 11 @ 4:36 pm
you can fix the scratch latency with the registry tool, huey has a video on his blog of how to do it, the jockey 3 has 3 times the clicks per rotation so that can only mean it's better at scratching than the jockey 2 and i have that set up pretty damn good, im thinking about getting one, but waiting to see if novation do a platter version of twitch, that would be the ultimate controller, apart from the vci-400 imo
geposted Mon 03 Oct 11 @ 4:45 pm
L.bombaHome userMember since 2011
I find scratching pretty useless on most controllers - it all depends how good your laptop is I guess....
geposted Mon 17 Oct 11 @ 12:48 pm
