Forum: Old versions
Topic: Can not see large file's preview.
XtcmaxHome userMember since 2011
Hello.
I just downloaded the VDJ HOME 3 days ago and and I don't know all the correct terminology, please bare with me. My problem as follows:
I decided to mix3 songs into 1 mix, which I did. After that I wanted to mix in another song at the end. When I try to load the large track I just mixed, the song "preview" bar is all messed up. I am talking about that window above the turntables, where you can see the song as a graph. (the intro, outro, main body). Is there a fix for this problem? Perhaps I should change some of the settings?
Please advise on the situation.
Thank you.
p.s. If it is a known issue and I am asking a redundant question, please forgive me, I don't know the terminology (name of that window, etc).
geposted Sun 02 Oct 11 @ 4:20 pm
right-click and scan the BPM
geposted Sun 02 Oct 11 @ 8:37 pm
Magic DJ,
when I click on Rescan BPM, nothing changes, I still can not see the full graph of the song in that window. I have only1.2 GB of RAM, could that be the problem? May be I am clicking in the wrong place? I tried re-scanning by right clicking on the song, lower part of the screen, and by right clicking on the BPM buttom on the top of the screen. Could you please write more descriptive suggestion.
Thank you very much.
geposted Mon 03 Oct 11 @ 4:44 pm
check the CONFIG/performance.
There is a setting there not to pre-load a song thats longer than XXXX.
Also, if the song is really long/big, it will not LOAD the Entire song (no graph). It will play and loads the rest while playing.
Songs get loaded into RAM, it you don;t have enought, the entire (long/big) song will not be loaded (not entire graph).
Read thru this
http://www.virtualdj.com/forums/135961/PC_Version_Technical_Support/Memory_Warning.html
geposted Mon 03 Oct 11 @ 8:31 pm
The Magic DJ,
Thank you for answering the question and providing the link. You really shed the light on my issue.
Best regards,
Xtcmax
geposted Mon 03 Oct 11 @ 9:59 pm
