Topic: Numark V7 with VDJ - Page: 2
Update..
After changing to 32.bit windows. After re-installing the decks and dowmloading the latest firmwear and version of both itch and vj. Still about 15 mins and boom they go down again.
After the decks freeze vj says the music is still playing. Although there is no sound
In the right hand side of the decks both the usb lights and the link lights do not come on..
And no matter how many times i switch on or off the decks until i restart my laptop, my laptop can not find them nor will the link lights or the usb lights switch on... Not saying anything but they do work grand with itch i just hate itch and refuse to use the program please help..
DJGIBBSY ,I have a question ,please post your laptop specs, so we can figure out what your Issue may be ,
Sincerely DJ Jamm
Hello,
I use VDJ 7.0.5b (the newest had a bug when it just came out)
with the drivers from Itch 2.2
you have to instal the V7's seperatly in Itch.
Laptop specs: core 2 duo 2.1 Ghz W7 32b
Good luck!
Linkerhandje
Sincerely DJ Jamm
hey buddy here are my specs.. PLEASE Help..
Pentium dual core t4300 @ 2.10
4 gb ram
32 bit windows 7
Djgibbsy, can you tell me what your sound setup is? I've been using my V7's for over 1.5 yrs without any problems. I use a Toshiba Satellite i7 processor, 4gb ram.
Using the two channel mixer set up with the v7 asio sound card..
I have a denonn x1600 mixer with the but i dont have that hooked up so only using one sound card. Also while they freeze or loose connection both the usb and the link lights do not come on...
Pm for more details
Cheers
Ter
