Forum: Old versions
Topic: m-audio oxygen 49, i want to make sounds!
tchimsPRO InfinityMember since 2011
Hello! So i've been djing for quite some time now and I would like to incorporate live keyboard sounds over my mix with the hercules rmx. How do I do this ? The oxygen 49 has only a usb connection so i assume it would have to be another channel to it, like a 3rd deck. I do not want to use it for controlling the tracks, I want to make fresh sounds with the keys being the actual notes. Thank you!
geposted Thu 13 Oct 11 @ 4:27 pm
The only type of music you can play with VDJ is pre-recorded tracks.
You can't generate keyboard sounds.
For that you'll need software such as Ableton Live, Cubase, Reason etc.
There are lots of similar keyboards that come with a 'Lite' version of suitable software in the box.
geposted Fri 14 Oct 11 @ 4:44 am
can any of the aforementioned software act as a channer for vdj ?
geposted Fri 14 Oct 11 @ 1:16 pm
What's a "channer"?
You can link some music software to VDJ with something called ReWire, which allows two apps to run in sync - one as master, the other as slave. With VDJ, it always has to be the master, and the linked software simply follows the tempo of VDJ.
geposted Mon 17 Oct 11 @ 5:05 am
