Hi everyone,
Before I ask my question I like to thank the maker of
Condensed 1.7
I wanted something simple and I found it in this skin. Since I download I have 6 months ago:
---Changed the clock size and color to stand out.
---Within the track path change the color to yellow to show that last 30 seconds of the song.
Here are a few point I like:
---I able to see art and title easily.
---All the major buttons are easy to see and close to each other.
How for my questions.
I have looked and looked but I haven't been able to find where to change the mouse pointer color. It since that all the skin MP are the same but I would like to be able to change it to the standard white color. When playing outside I find it hard to find the dang thing...
Lastly, doesn't this skin come it a lighter color for outside gigs...?
If not, is there a way I change it to something I can see in the daylight...???
Thanks all for take a read at my questions.
Condensed 1.7
geposted Thu 13 Oct 11 @ 10:06 pm
You can change the mouse pointer color to white via windows registry. The best way to do it is to download the registry tool from the plugins area...
geposted Fri 14 Oct 11 @ 12:25 am
For a daylight skin put the bitmap into PS or paint and select invert image, select save as and give it a name, then close the programme and choose no to save changes this way you will be able to keep the original skin... should do the trick for you.
Or use Jeremk's skin creator tool I think you can do the same thing.
geposted Fri 14 Oct 11 @ 12:55 am
Actually it is the Skin Resizer Tool Tayla :)
Download: http://www.virtualdj.com/addons/7187/Skin_Resizer_Tool.html
Video Tutorial: http://www.youtube.com/watch?v=7ZbaTP1Vf8A
In just a few clicks you can use the Skin Resizer to make a daylight skin.
geposted Fri 14 Oct 11 @ 5:38 pm
Sorry, me bad.
geposted Fri 14 Oct 11 @ 5:40 pm
