Forum: Old versions
Topic: Denon MC-6000 Cues & Samples Mapping
Has anyone mapped the the Cues and Samples buttons on the MC-6000 so that there are 8 total of each usable instead of the default 4 mirrored on each deck?
Basically i am trying to have 8 different cues and 8 diffrent samples at one time instead of 4. Thanks in advance
geposted Wed 19 Oct 11 @ 11:37 pm
I will have a look at this tomorrow night and advise, although I don't think it's possible.
You will need a VDJ Pro licence to be able to do this though.
Keith
geposted Thu 20 Oct 11 @ 4:10 pm
Thanks man. Looking forward to see if this is possible!
geposted Thu 20 Oct 11 @ 6:13 pm
How do you want to select the deck that the buttons will operate on, you could set up a shift that you action or you could make it work on the default deck (one in the pfl).
geposted Fri 21 Oct 11 @ 1:06 am
Synthet1c, I'm not follwing your question.
But what im looking for is to have a 4 difffrent samples triggers on deck a and and 4 different samples on deck b at the same time. By default when you activate samples you get the same 4 on both decks.
Now that i think of it though I guess I would not need such mapping for the cues. the cues would not be necessary since VDJ only supports 4 hot cues.
geposted Fri 21 Oct 11 @ 6:35 am
VDJ supports up to 99 cues. You only see 4 on your skin.
I personally think it is better being deck independent. How would you feel about using the buttons for 1-4 and the button with a shift key for 5 -8?
Keith
geposted Fri 21 Oct 11 @ 8:01 am
keith,
With the way you suggest what would happen to the cues though? I would like to keep the cues functionality.
Thank you for your efforts.
geposted Fri 21 Oct 11 @ 9:21 am
