Ok guys any help would be very nice. Just bought 2 v7 1. because they are great in my mind and 2. because virtualdj has them as advertised products that are compatable, I thought since it was on the site it would be very easy and basically plug and play. I already have other setups so its not like im new at this. Basicallly my problem is that my master deck sounds alittle off and my slave deck is playing at double speed I have already done the tutorial on the other forum and still nothing at all. Please any help at all!
geposted Tue 25 Oct 11 @ 7:27 pm
You have installed it that way?
http://www.virtualdj.com/forums/130863/Hardware_Technical_Support/Numark_V7_-_Setup_-_1_and_2_unit_settings.html?page=1
geposted Wed 26 Oct 11 @ 9:29 am
The double speed ting will go away if you turn on left deck forts, then plug in second deck and then power on.
geposted Wed 02 Nov 11 @ 2:18 pm
