Forum: Old versions
Topic: Numark Virtual Vinyl and Asio4all help!!
Hallo guys! I am new here, and i really need som help!
So I bought myself some days ago a dj set and a numark virtual vinyl so i could start to learn how to mix and scratch, but anyways i am having some problem getting everything to work in Virtual dj pro. I am not sure if i have every cable also, but since i only got 4 red and white cables in the numark virtual vinyl packadeg i expect thats the only cables you need, or do i have to buy more? but any ways i have connected every thing as it says in the paper but when im going to config everything i get two error saying ''error in the Asio sound driver: your soundcard is probebly not conected or the settings are incorrect'' and ''error in the asio sound driver: not enough channels''
My dj kit is : two numark tt-200 vinyl players, one vestax VMC-002xl mixer and the numark virtual vinyl.
i have been check around on the internet like crazy since yesterday and haven't found any help at al, so please if someone knows what the problem is please help me!!
geposted Sat 29 Oct 11 @ 4:39 am
Why on earth are you using ASIO4ALL????
You need to use the sound interface box supplied with Virtual Vinyl - and install the correct drivers that came supplied with the interface.
Uninstall ASIO4ALL, you don't need it.
Once you have the interface connected, and the drivers installed, select that interface in the VDJ configuration.
geposted Sat 29 Oct 11 @ 4:49 am
Double post. Moderator please delete.
geposted Sat 29 Oct 11 @ 4:52 am
okej thanks! i am a total noob on this so i thought u had to use asio haha, but i will try what said and hope it works! :)
geposted Sat 29 Oct 11 @ 5:35 am
it says that i have installed the latest driver for numark virtual vinyl, but voth virtual dj and cue cant find it, and i have uninstalled asio but it still fins asio, and one thing more when i installed the driver it said that i was a bad file so it would not installe and this is the file i downloaded from numarks site!
this thing is pissing me off, why wont it work?!
geposted Sat 29 Oct 11 @ 6:43 am
The drivers for the box are built into virtual vinyl. you will need to install virtual vinyl for it to work. Also the virtual vinyl box does not like 64bit OS
geposted Sat 29 Oct 11 @ 8:24 am
That's the thing it doesnt do, and since i didn't get a cd to my box i dont know what to do to get this thing working!
geposted Sun 30 Oct 11 @ 4:38 am
Go back to the shop you got it from then, as it sounds like you are using a cracked version which will have problems!
geposted Sun 30 Oct 11 @ 7:21 am
