I have a sampler button - that no matter what - shuts down the program whenever I click Play. I have figured out that if I save a new sample to it - it will be ok.... But then I noticed when I was working with several different sampler files open at the same time - it crashed again... Is there a patch to fix this?
I currently have the latest Home 7 Free version - is there a difference in the # of crashes in the purchased version? I have done a couple of donated events - not getting paid - and I have a charity event I am going to do ---- and I dont want to have my system crash in the middle of it.
geposted Mon 31 Oct 11 @ 8:33 pm
You are possibly using a corrupted sample file?
Try opening the affected samples in an audio editing application such as Audacity and then save them again as a new file. Then use this new saved file instead of the old one.
Please also post your crashguard report if you get one - Please see: https://virtualdj.com/wiki/Crashguard.html
Also, if you are doing a live event, you should always have some sort of backup solution to fall back on in an emergency - Please see https://virtualdj.com/wiki/Do%20I%20need%20a%20backup%20system%20on%20stand-by.html
geposted Tue 01 Nov 11 @ 8:03 am
