Forum: Old versions
Topic: Crossfader working incorrectly!
I have VirtualDJ LE and a Numark Mixtrack (not the pro version). The crossfader in VDJ LE is functioning incorrectly. Instead of just fading from one deck to the other, this is what happens:
I'll load one song in Deck A and start playing it. Even if I have nothing loaded in Deck B, when I start moving the crossfader from the left to the right, the volume on Deck A starts going down. Once I get to the middle of the fader, Deck A is at half-volume.
This is a huge dilemma for me because my mix gets quieter whenever I transition between songs. Can someone please help?! I have a show this weekend and I can't do it unless this gets fixed.
Thank you!
geposted Tue 01 Nov 11 @ 3:01 pm
i just recently got the VMS4 and installed the Virtual DJ that comes with it, and i notice when i use my Speakers and Headphones when i move the Crossfader the sound moves in both Speaker and Headphones,
HELP!!!!
geposted Thu 24 Nov 11 @ 12:16 pm
Thank you!
Unfortunately you can not change the crossfader behavior with the LE version. You can do that with the Pro Full version which you may get with a large discount. http://www.virtualdj.com/products/oem.html
Alternatively you may use the deck volume faders to mix instead of the crossfader
geposted Thu 24 Nov 11 @ 12:52 pm
HELP!!!!
What LE version do you use ? Check that in your Config setup window
geposted Thu 24 Nov 11 @ 12:55 pm
