Forum: Old versions
Topic: HELP ME PLEASE!
SO BASICALLY THIS IS WHAT I WANT TO DO:
DECK 1: SONG A
DECK 2: SONG B
DECK 3: SONG C
WHAT I WANT TO DO IS ACTIVATE A SEPERATE DECK TO PLAY ONCE IT HITS A CERTAIN POINT ON THE OTHER DECK.
E.G. DECK 1 IS PLAYING SONG A. ONCE SONG A HITS "02:34.2" THEN I WANT DECK 2 TO AUTOMATICALLY PLAY FROM THERE. OR EVEN BETTER, WHEN DECK 1 IS PLAYING SONG A AND HITS "02:34.2", I WANT DECK 2 TO PLAY FROM A SET CUE.
DOES THAT MAKE ANY SENSE AT ALL? IS IT POSSIBLE?
BASICALLY I WANT TO SET IT UP SO WHEN I AM PLAYING AND INSTRUMENTAL INSTEAD OF MANUALLY TIMING WHEN TO PLACE THE ACAPELLA OVER IT, I WANT IT SO IT CAN DO IT AUTOMATICALLY AT AN EXACT TIMING.
PLEASE HELP OR ASK FOR ME DEETS IF THIS IS TO CONFUSING :P:P
geposted Sat 05 Nov 11 @ 2:15 am
not possible in vdj at the moment and may never be, we would need a plugin 'cue events' upgraded to accept script, but if that is what you do every single time you play the instramental, why not just use a daw to record a mashup, an easier way again would be to use mixmiester, either for the recording or the whole mix... no one is going to think your awesome if you are doing 4 things at once, they won't even notice.. They will only think your awesome if you sound good doing it
geposted Sat 05 Nov 11 @ 2:39 am
