Forum: Old versions
Topic: Best 4 output Soundcard?
Pat_DJPRO InfinityMember since 2007
Hi,
Im looking a good quality for price for a 4 outputs soundcard. I would prefer not paying 300$ for a soundcard but if that's what it has to be, i could maybe go with that.
Any recommendation?
Thanks
geposted Sun 13 Nov 11 @ 8:51 am
I'd say get an Native Instruments Audio 8, hands down the best soundcard I'd every had. Even better sounding then my SL3.
Happy Hunting
Huey
geposted Sun 13 Nov 11 @ 8:56 am
Dee Jay Trim 4+6 has a big bang for buck. Good sound, good price, a bit big though to be fair.
geposted Sun 13 Nov 11 @ 9:02 am
I was looking at the audio 8... Seems very good.. a bit steep for the price though.
geposted Sun 13 Nov 11 @ 9:10 am
for a dj soundcard you can't go past native instuments... it will introduce you to so much sound you just couldn't hear before. check ebay I got an audio 8 for $140aus
geposted Sun 13 Nov 11 @ 9:16 am
Great. Im looking around for the audio 8, im from canada but if anyone sees a great offer let me know :)
geposted Sun 13 Nov 11 @ 9:25 am
If you only need four outs (i.e. two stereo) then the Traktor Audio 2 would be enough.
geposted Sun 13 Nov 11 @ 10:52 am
geposted Sun 13 Nov 11 @ 10:14 pm
Gigaport HD is a very popular USB audio interface - but it only has outputs.
If you want something similar that also has inputs (so you can use it with timecodes for example) look at the MAYA 44 USB.
geposted Mon 14 Nov 11 @ 6:23 am
After looking at the Audio 8 DJ, this card seem to be exactly what I need. Im able to get for 274$CAD. Would you say it is a good deal?
geposted Mon 14 Nov 11 @ 7:37 pm
I dont know what that is in US dollars but I got mine brand new for 280 bucks off of Ebay.
Its a great card
Huey
geposted Mon 14 Nov 11 @ 7:51 pm
$400 is a good price for what it offers you, it started retailing at $800
geposted Mon 14 Nov 11 @ 7:58 pm
beatbreaker1, 280 for a brand new card, thats a crazy deal. If you ever find something similar let me know!
geposted Mon 14 Nov 11 @ 9:08 pm
Although thats used and doesnt come with any accessories. I dont even think it comes with the power cable.
geposted Tue 15 Nov 11 @ 6:44 am
geposted Tue 15 Nov 11 @ 6:53 am
Thanks. I just contacted this seller.
Hopefully he'll ship to Canada.
geposted Tue 15 Nov 11 @ 9:53 am
Hey all,
Thanks everyone for your help.
I finally bought myself a Audio 8 DJ :)
Can't wait to receive it and testing it.
Anything I should know about the card?
geposted Wed 16 Nov 11 @ 6:27 am
not really, it's pretty basic, just plug everything in and set it up, athough come to think of it i did have issues with the drivers on the NI website, I had to use an older one as the newer ones didn't work on my lappy, once that was sorted, I have never had another problem with it.. If you have the same issue just start at the newest and work your way back until you find one that works.
geposted Wed 16 Nov 11 @ 6:44 am
Thanks for the heads up synthet1c.
geposted Wed 16 Nov 11 @ 7:17 am
