Hi
I'm hoping someone can point me in the right direction, or tell me where i'm going wrong...
I've downloaded the Core Audio Drivers for my SL3 box, it's got the latest firmware and i'm using the most up to date version of Virtual DJ.
In config I have gone to advanced and assigned the channels individually to the SL3 box so deck 1 is channels 1 & 2 and deck 2 is channels 3 & 4.
Everything works fine, the files play on the screen however NO SOUND comes out of the box and into the mixer... very very confusing!
It has worked for me once, and that was after plugging and unplugging and restarting Virtual DJ numerous times - since then everytime I try I get absolutely no sound coming from the box even though it appears everything is working correctly and the files play on Virtual DJ fine.
Help would be greatly appreciated
geposted Tue 22 Nov 11 @ 3:20 pm
I my be wrong but have you tried opening serato first and closing it and then opening VDJ. I remember someone saying it had to activate the box before you could use it with VDJ. I may be completely wrong but maybe it helps.
geposted Tue 22 Nov 11 @ 4:52 pm
Maybe this video I made will help, also go the start menu and click on the Serato folder. It should expand and you'll see an icon that says SL asio, click on that and install it. Well that's how i do iton a PC, lol!
geposted Tue 22 Nov 11 @ 8:47 pm
