I know I've done it once before, but i forgot.How do I import everything from virtual dj 6 into the virtual dj 7. I want to import everything including my database, history, playlists,etc.
Thanks in advance
Thanks in advance
geposted Sat 10 Dec 11 @ 3:55 pm
make sure you have a backup first (the database is located n the ROOT of the Drive where STUFF is stored.
Once thats done, just install VDJ7 and everything will do it automatically.
Now the PLAYLIST and HISTORY etc.. are located in you user/profile/documents...../virtualDJ/etc..etc... Backup that Entire Folder just in case.
Once VDJ7 is installed, if your playlist, history etc... are deleted during install, copy the files from BACKUP.
geposted Sun 11 Dec 11 @ 7:25 pm
