Forum: Old versions
Topic: Two deck hardware, 4 deck controller
First of all, is this possible? If so, how would I configure it? My hardware is the Numark Mixtrack and the software is Pro 7. I would like to configure it so that the left hot que 3 button toggles between deck 1/3 and the right one toggles between 2/4. Thanks in advance!
geposted Tue 13 Dec 11 @ 5:40 pm
geposted Wed 14 Dec 11 @ 7:40 am
thanks for the reply!
I did what that guide said, and none of the results gave me what I've wanted. the invert_controller is close, but when i press it, it slides the control along all 4 decks. first deck 1 and 2. then 2 and 3. then 3 and 4. then 4 and 1. i want the left cue to toggle the left side of my controller between 1 and 3 and the right side to toggle between 2 and 4. none of the commands on that page did that for me. what are the exact commands to do this? btw, ive never done any mapping before, so im a noob at this.
geposted Fri 16 Dec 11 @ 3:03 pm
geposted Fri 16 Dec 11 @ 3:55 pm
I did a very similar set up using numark's total control. And what I did is I used both pitchfaders as deck three and four volume. The only problem that most people have is that then they lose the functionality of adding a pitch slider. What I did is I just turned one of the knobs on the deck using the shift option to be making a pitch slider. So basically when I hit shift that three and deck for volume sliders are volume sliders and when I let go of Schiffer deck three and deck for it is a pitch slider simple solution.
DJ KAACE.
geposted Fri 16 Dec 11 @ 7:21 pm
