Forum: Old versions
Topic: hercules mk4 sound issue in head phones..
the sound finally working after I removed the pro program and installed the free version. Then I updated to pro. then it crashed and lots the head phones... its somewhere in the code or something.. Its driving me crazy been on this for 5 hours.. anyone , yes the asio is on and the settings are right but im missing something in the mapping its like its missing the volume for the head phones.. i dont know... anyone , buler , buler.....
geposted Sat 17 Dec 11 @ 2:22 am
Just download the new driver from Hercules sites and once finish the updates do and configure the setting of the soundcard by doing it in the "advance config" then "sound setup" then you have + sign to add the inputs and outputs of the soundcard be sure like deck 1 & deck 2=output 1&2, main out & headphones=output 3 & 4 try to tweak a bit and you will get it right.Just download the new driver from Hercules sites and once finish the updates do and configure the setting of the soundcard by doing it in the "advance config" then "sound setup" then you have + sign to add the inputs and outputs of the soundcard be sure like deck 1 & deck 2=output 1&2, main out & headphones=output 3 & 4 try to tweak a bit the setting of the headphone in the monitor cue, mix knob and the volume knob near to the crossfader side there you can the 3-knobs and you will get it right.
geposted Sat 17 Dec 11 @ 8:17 am
i did all that and there is still a issue.. its something in the programing of virtual dj , i have never had so many issues..its almost unreal.. its a issue with the the button lay out. I had to re write some of it...
geposted Sat 17 Dec 11 @ 7:00 pm
the driver is in the original cd that came with it , the virtdjpro doesnt have that driver set up. had to steal it and add it to my files. problem fixed.
geposted Thu 26 Jan 12 @ 4:57 pm
