Forum: Old versions
Topic: Mic/headphone HELP!
Hello, Im a party DJ and need help! I want to connect a usb microphone and usb headphones, when i sent it up in the settings, i can have the mic on, but i cannot cue up tracks at the same time!!!
ALso, would it help if i just had a usb headphone (i have a headSET with a usb sound card ) and im wondering if i brought a normal usb headphone, i would be able to cue up tracks, and at the same time, do public announcements?
Sorry if its a bit complicated! Im using VDJ Pro
geposted Fri 30 Dec 11 @ 8:32 am
It depends on the USB Soundcard you bought, if it does support multichannel and it has a driver or just plug in it is being recognized by the software like VDJ & windows then it is fine, you will have to configure and do the setup of your USB soundcard in the VDJ config menu. Just do the tweaking in the config sound setup you will get it fix. Also try to configure your inputs & outputs in the mac application then utilities and choose "audio midi setup" you find your USB sound source like your soundcard and do the necessary settings.
geposted Sun 01 Jan 12 @ 4:43 am
