Forum: Old versions
Topic: virtual dj & numark mixdeck - reassigning deck
Hello,
recently I am facing strange problem with random deck change. I am starting to play & my physical left deck is assigned to left deck in VDJ, right- to the right one. And suddenly song from the VDJ right deck jumps to the left one and it creates a lot of mess. And only left (physical) channel volume is working - for both decks. I have tried different configurations (choosen sound card: Numark or Asio) and choosen option 'external mixer'. Does anyone face similar problems?
Thanks
geposted Mon 02 Jan 12 @ 8:00 am
Ok, it seems that I found root cause. Originally I tried to fix it by changing settings in configuration tab, by choosing different channel assignment, different sound cards etc (ie I have Numark sound card & Asio, both come with the equipment). But doing so I did even bigger mess. The root cause was eject button in my Numark - by clicking it once you are reassigning physical decks with virtual ones. Clicking it twice - everything goes back to normal. But.. clicking it once and messing with settings - distarter is close, especially at party and after few drinks :)) Ok, hopefully my lesson will be useful for other Numark Mixdeck / Virtual DJ users.
geposted Mon 02 Jan 12 @ 10:06 am
I have a similar problem today but nothing work!!! arghh
geposted Thu 01 Mar 12 @ 11:01 am
I have the same problem it switchs the left deck is play but i control it with right deck on the mixdeck plzzzzzzz help
geposted Mon 12 Mar 12 @ 3:12 am
If you hit the eject button on the deck that is playing it will switch to the opposite side, hit it again it will go back to the correct side.
You may have hit the button accidently while playing and caused it to go to the other deck.
geposted Mon 12 Mar 12 @ 8:55 pm
