Forum: Old versions
Topic: Change default desk?
Is there a way to change the "default" desk, other than just being the last deck loaded?
Ideally, there should be a way to make a keyboard shortcut to swap desks (and explicitly set the default to 1 or 2 would be nice also) plus a variable you can use as an indicator on your skin to show which deck is the default.
geposted Wed 03 Sep 03 @ 8:12 pm
Or..... the "Active" Desk.......
Perhaps if someone enlightened me as to the actual inner workings of "active" and "default" desk, it may be all I need.
As far as I can tell, the default desk is the last one loaded, and the active deck is the previous deck loaded.
Is this correct, or am I missing something here?
geposted Wed 03 Sep 03 @ 8:32 pm
do you mean Deck or Desk?
Deck=player (there are 2 decks in VDJ 1 and 2)
geposted Wed 03 Sep 03 @ 11:44 pm
Wireless, they are referred to as desk in the VIrtualDJ manual [:o)
geposted Thu 04 Sep 03 @ 1:32 am
