Forum: Old versions
Topic: Midi Fighter mapping?
Hey so I have midi fighter and I want to map a button as a "Shift" so I can have 30 functions instead of 16. Is this possible to do and how would I do that?
geposted Mon 16 Jan 12 @ 12:15 pm
could you get me the VID and PID of the midifighter, so I can finish a definition file for the it?
to get it go into control panel --> devices --> right click the midi fighter --> properties --> hardware tab --> properties --> details tab --> in the drop down menu select "hardware id's"
my istage says this, you need these aswell, and add to your device line
USB\VID_1D03&PID_002F&REV_0100&MI_0
In answer to your question to map a shift function you just set a variable with one button, then you query the state of the variable being on or off and have conditional branching so vdj knows what action to perform, It may sound complicated, but it's actually pretty easy as you can just use the following syntax
to set the shift there is two options... temporary and toggle
set 'shift' while_pressed
or
toggle 'shift'
for everything you want shifted
var 'shift' ? action if shifted : action if not shifted
eg
var 'shift' ? delete_cue 1 : hot_cue 1
As you know you need to upgrade to pro to be able to map extra controllers
Thanks. I know I gotta upgrade, I am on my friends VDJ just tryin it out
check your pm
