Forum: Old versions
Topic: denon HC4500 - VDJ keeps Crashing :(
Currently have a laptop, just dj use,
Denon hc4500
vdj 5.2 - jp boggis mapper
In the last 2 weeks its crashed 6times :( been using this set up for last 16months and had no problems.
any suggestions??
geposted Sun 22 Jan 12 @ 2:08 pm
We'd recommend upgrading to the latest VirtualDJ v7.0.5b.
The old DLL mapper is obsolete and is no-longer supported.
VirtualDJ v5.2 is also a very old version and may also have bugs that are fixed in later versions of the software.
You can either use the built-in mapping and modify it suit your OWN requirements or use a custom VDJscript mapper made by other users: http://www.virtualdj.com/addons/controllers.html?category=best&order=default&search=4500
geposted Sun 22 Jan 12 @ 2:52 pm
I tried some of the mappers with VDJ 7, but theres no like Documents that tells you on the button functions? thats why went back to VDJ 5.2
Is there any threads on here or Help (video tutorials) on how to remap the controller on vdj 7? I have no idea
Thanks
geposted Sun 22 Jan 12 @ 3:58 pm
geposted Sun 22 Jan 12 @ 5:00 pm
