I am running Numark Cue (VirtualDJ) version 7.0.5.
I have an AMD Radeon HD 6470M video card on my laptop.
Windows 7 64-bit
The videos don't freeze all the time, and when they do freeze....I can just re-load the video on the other deck and in seems to fix it.
However, it shouldn't be freezing at all!
Is there a way to fix this?
Windows 7 64-bit
geposted Mon 30 Jan 12 @ 8:34 pm
Still waiting for an answer.
geposted Tue 28 Feb 12 @ 12:28 am
Same problem but i have a core i3 2330m with an integrated HD3000 gpu.
The registry tool will repair this issue?
Regards.
Regards.
geposted Mon 12 Mar 12 @ 10:11 am
Have either of you checked here:
http://www.virtualdj.com/wiki/My%20video%20output%20runs%20slowly%20or%20is%20very%20choppy.html
or here:
http://www.virtualdj.com/wiki/Video%20Memory%20Issue.html
I understand that the second one is referring to memory issues, but it may be an issue for you without throwing an alert.
Also, since you are both using Radeon chipsets, search the forum for conversations about Radeon drivers, maybe you need an older version.
And, again, since they are both laptops, check to make sure that yours is not effected by the dual graphics chipset problem that will cause video issues with the laptop going into a power saving mode and using the weaker chipset.
or here:
geposted Mon 12 Mar 12 @ 2:43 pm
Try disable Aero
geposted Tue 13 Mar 12 @ 8:54 am
I have had the same problem when this update came out , easily solved go back to 7.02.
There seems to be a bug in this version which I mentioned when it first got released.
Unfortunately Numark are no where near as quick with updates compared to virtual dj
Best Regards
Best Regards
geposted Thu 15 Mar 12 @ 6:53 am
