What is the easiest and cheapest method to get the windows version of virtual dj to run on my Mac?
I have read about bootcamp and I know I need a copy of windows. Is there any easier method? I will only be using the windows partition for virtualdj.
geposted Sun 05 Feb 12 @ 10:11 pm
Bootcamp is the best choice..
geposted Sun 05 Feb 12 @ 10:39 pm
Thanks Clint, that is what I think I am going to do. What version of Windows did you install? Have you used VMware fusion before? I have a copy and thought I might give that a try as well.
geposted Mon 06 Feb 12 @ 12:46 pm
Either XP or Win 7 will work fine.
VDJ will not work with Vmware or parallels as they are virtual environments. I have tested this in the past and it's a no-go.
Keith
Keith
geposted Tue 07 Feb 12 @ 6:22 am
I used Win 7 pro it runs like a champ. One thing I like is I am able to see the mac partition threw VDJ, since I use both side.
geposted Tue 07 Feb 12 @ 8:12 am
