I've been using the VSM4 for about a year now, and will be getting the VMS4.1 soon,
I'm using DJ Dad's mappings and have an advanced configuration set in VDJ,
Will the .1 just plug in and work, or will i have to remap everything?
geposted Wed 08 Feb 12 @ 2:13 am
You can use the same mapper. A user has reported that the same files can be used with the new VMS4.1. Maybe you will have to do a rename in the files, maybe not. But it wont be hard i guess.
In case you need any help on making the 4.1 working with my mapper , i d be glad to help.
geposted Wed 08 Feb 12 @ 1:59 pm
Thanks DJ Dad, I'll let you know if I do.
geposted Sun 12 Feb 12 @ 6:35 am
