Forum: Old versions
Topic: Virtual DJ won't match with current iTunes library
Hello!
I love this program and until 2 months ago used it all the time for DJ gigs with my Macbook.
That is until the software stopped using iTunes properly.
The program now uses my iTunes library from about 2 months ago. I've added a lot of music and playlists since then and can't seem to get them to match up properly.
I've tried uninstalling and getting all the proper updates but still nothing.
any ideas?
Thanks!
Phil
geposted Fri 02 Mar 12 @ 2:33 pm
ssdjtazPRO InfinityMember since 2011
have you tried right clicking on itunes in your VDJ browser list in the left pane and selecting "reload itunes" ?
geposted Sun 04 Mar 12 @ 8:30 pm
I have tried that yup, and still nothing?...
geposted Mon 05 Mar 12 @ 12:55 pm
Same issue here. Right-clicking and refreshing in VDJ doesn't fix the issue. Any other ideas?
Erik
geposted Fri 09 Mar 12 @ 4:22 pm
I had that issue recently. It has to do with the naming convention of the current itunes library file. I'm looking for the thread where i found my solution for you now.
geposted Fri 09 Mar 12 @ 6:48 pm
geposted Fri 09 Mar 12 @ 6:53 pm
Fantastic! that fixed it. Is there any chance that Virtual DJ will give the user the ability to select the library? regardless of the name? I think that would be the most flexible way to handle these types of issues.
Thanks,
Erik
geposted Sun 11 Mar 12 @ 1:55 pm
