Hey all I'm new to the VDJ crew but I've already run into some issues with my recordings, mainly them skipping and ruining the tracks. I just downloaded the program tonite and both recordings I've made so far have been skipping every 10 to 15 seconds. The first recording I s horremade was when I was running lots of processes at the same time, but the second recording was with everything but VirtualDJ closed down and it still skips horrendously. What do I do I'm about ready to break my computer and need some help quick! Please advise Thanks!
geposted Fri 02 Mar 12 @ 10:30 pm
Well it's hard to judge what might be causing it because you've not provided any details about your computer....
It could be that your computer is not of a high enough spec to handle the task.
It could be that your hard drive is fragmented.
It could be that you have too many background tasks running.
geposted Sat 03 Mar 12 @ 6:17 pm
apparently you haven't looked at the topics above either
try selected software guides / skipping .......
geposted Sun 04 Mar 12 @ 8:41 pm
