Forum: Old versions
Topic: How to download Video Effects and Transitions?
Anyone? Sorry but I just purchased this Macbook Pro, use to using windows. Plus, new to Virtual DJ also. Can someone tell me how I get and install the Video effects, Clipbanks and transitions that I downloaded from the download section of this site. I selected the MAC version and I see that a file downloaded to in my "downloads" folder. When I click on the icon, I get "Clipbank name to control:" Where do I go from here? How do I get the clip bank and video effects? I tried 3 different downloads and can't find out how to install or upload. I need a download and upload for dummies...Thanks in advance!!!
geposted Mon 05 Mar 12 @ 12:44 am
The plugin you are referring to there is my clipbank random plugin.
For use with the default clipbank, you just copy the bundle file into Documents\VirtualDJ\Plugins\VideoEffect\
The script file you ran is if you create multiple copies of your clipbank - it allows you to create multiple copies of my random plugin so you can use it against different clipbanks.
how can I get a mosaic style video effect for mac?
