Forum: VirtualDJ Skins
Topic: Chance skin in another resolution :-)
geposted Thu 15 Mar 12 @ 5:09 am
JeremKPRO InfinityModeratorMember since 2004
Hi,
You can easily perform this with the Skin Resizer:
http://www.virtualdj.com/addons/7187/Skin_Resizer_Tool.html
Unzip the skin, open the XML file in the Skin resizer.
Output size: 1280x800
Resizing method: Browser Resize or Smart (in this case both methods will perform the same action)
Then generate the resized skin.
geposted Thu 15 Mar 12 @ 7:30 am
i know this, but then the jogwheels are not round. And the text smaller than normal.
You know what I mean, if i mak this i could also change to fullscreen.
chris
geposted Thu 15 Mar 12 @ 9:40 am
Using "Browser Resize" or "Smart Resize" has never made the jogwheels not round, nor the text smaller.
Give it a try ;)
geposted Thu 15 Mar 12 @ 9:41 am
Hi
Many Thanks. This should be possible.
Chris
geposted Thu 15 Mar 12 @ 2:13 pm
Hi
I unzip the file, but there is no XML and BMP.
I work with the mac version.
Chris
geposted Thu 15 Mar 12 @ 2:23 pm
geposted Thu 15 Mar 12 @ 2:33 pm
And how it works of ''Browser Resize'' in Skin Resizer Tool?
geposted Thu 15 Mar 12 @ 3:18 pm
@ Jeremk
When you download the Skin Resizer tool, you get an app you must open. - i know this.
I
Then unzip the skin file to get the XML and BMP files. - I unzip the Pioneer_DDJ-V1.zip.
Then there is a file:
install_Pioneer_DDJ_V1_.app
then there is a folder:
Contents
then two folders and two files:
folder: MACOS
folder: Resources
file: Info - Quick time Preferences
file: Pkginfo
And there is no file XML and BMP.
I change other skins with XML and bmp, with the skin resizer or the skin creator. But now I don´t know how.
chris
The tutorial for the Skin Resizer is in the wiki:
http://www.virtualdj.com/wiki/Skin_Resizer_Tool.html
geposted Fri 16 Mar 12 @ 3:50 am
I think you are getting mixed up.
When you download a VirtualDJ skin, you get a zip file. Open the zip file and you will get an app (installer for the skin).
Double-click on the app and it will install the skin in Documents/VirtualDJ/Skins
To use a skin with the skin resizer, you need to go to Documents/VirtualDJ/Skins and unzip the skin you want to resize.
geposted Fri 16 Mar 12 @ 4:21 pm
