Forum: Old versions
Topic: Recording off mic?
Hi guys,
Im sure this question has been posted up before but to all might God himself, I cant seem to find any "pacific" answer to this; even looking in google search.
Is there a way to record JUST your voice from the mic, without playing anything on the DDJ ERGO? I seem to press record, but later when I press stop after saying a few things in the mic, nothing seems to be recorded.
geposted Fri 16 Mar 12 @ 2:46 pm
DJMistaCPRO InfinityVDJ Radio TeamMember since 2009
Might be that the console is just a pass thru to the master out. If so your VDJ will not record anything or if broadcast to online radio it will not be picked up. What are your sound settings like?
I would suggest the following in the sound config option:
Inputs: Mic Option
Ouputs: Headphones (Master: Chan 1&2 / Headphones: Chan 3&4)
Sound card (PC): ASIO - Pioneer DDJ ASIO (from the drop-down menu)
Sound card (Mac): 4-out card - Pioneer DDJ ERGO (from the drop-down menu)
Click APPLY
If not then the console is only a pass thru and like mentioned above you will never get VDJ to record the mic.
PS: It might be that you are also using LE version and it has limited on the recording not sure on this tho.
You can get VDJ Pro at a discounted price if you havent done so already with your copy of LE Verison here http://www.virtualdj.com/buy/index.html
Hope this helps
Charlie.
geposted Thu 22 Mar 12 @ 7:59 am
