I cant seem to get my head around why VDJ just crashes now & then around 3 hours of mixing live?
done & read most things:
typhoon should be at 768ms
wifi off
Anti virus off
it wont even shut down?
Cpu meter is low
m11x 3r
£160 SSD
i5
Getting really annoyed now done it twice live?
Is cause the vestax typhoon is crap? & VDJ LE install_virtualdj_le_typhoon_v7.0.2.exe
I want to upgrade but hmmm
Any Other people have this ramdom crash?
please help
wifi off
Anti virus off
Cpu meter is low
m11x 3r
£160 SSD
i5
please help
geposted Mon 26 Mar 12 @ 12:19 pm
yessssssss i have too mate, i think for the first 2 crashes i was using usb 3.0 but i have put it 800ms disabled wifi in device and turned off aniti virus and bluetooth mouse.
yep i was going to upgrade aswel but whats the point? i want to know whats up with either vdj le or tyhpoon?
geposted Wed 25 Apr 12 @ 4:02 pm
try usb 2.0... and maybe increase the latency to see what happens... if your not using le it could be a bad effect or something... but send your crashgaurd report into support so they can see the cause and help you find a solution..
...and did you just reply to yourself in the third person? LOL
geposted Wed 25 Apr 12 @ 9:55 pm
lol i copied & pasted it on wrong section oh wel, got mate who uses m11x too, what lappy you got
how you find the crash guard?
geposted Thu 26 Apr 12 @ 8:23 am
lets just say not an alienware lol.... crashgaurd report is TXT doc in the virtualdj folder in "my documents"
geposted Thu 26 Apr 12 @ 9:04 am
