The DJM700 Roll FX is combined to a manual Filter (LPF or HPF)
By default, the filter’s cutoff frequency allows the Roll beat effect to be
applied to a desired frequency band alone.
If you trigger the Double Filter button, filter’s cutoff frequency is applied to the Roll and Track as well
BEAT select buttons : 1/8, 1/4, 1/2, 1/1, 2/1, 4/1, 8/1
The effect is synchronized automatically to the BPM
Slider 1 : Mix Track / Roll > controls mix between the original direct sound and the sampled audio
Slider 2 : Frequency Cut of Filters
- from middle to left : gradually decreases the low-pass filter\'s cutoff frequency
- from middle to right : gradually increases the high-pass filter\'s cutoff frequency
![](/image/5508/86708/ROLL DJM700 PUB.jpg)
geposted Sat 31 Mar 12 @ 5:51 pm
dowloading available
geposted Sun 01 Apr 12 @ 12:12 pm
