Hi Guys asked a few times before and have been using mixlab 3.1 as a default for a while. I am after a skin with high contrast text. turntableism is a good one just not for 1280 x 800.. i presume that if there isnt one a skin resizer would be the only option..
Thanks Guys and hope you can help
Marky P
SoulCityGrooves Radio
Marky P
geposted Mon 02 Apr 12 @ 4:59 pm
I have a few skins at 1280...
http://www.virtualdj.com/addons/12884/DASHLIGHT2_0.html
http://www.virtualdj.com/addons/12666/Trace_2_0_Pro.html
geposted Fri 13 Apr 12 @ 1:56 pm
Hi,
It really depends on what is your setup. If you are using a midi controller or Timecoded system you might not need all functions of MixLab on the screen.
This is a good skin with high contrast:
http://www.virtualdj.com/addons/11597/TCmania_Bright.html
geposted Mon 16 Apr 12 @ 11:47 am
Use your skin you LIKE then go to (System Preferences).Then Universal Access : Display WHITE on Black..................
AsTheDj
AsTheDj
geposted Sun 22 Apr 12 @ 4:17 pm
